Can't apply a ID to the anchors
Sjuul
Post by Sjuul » Fri May 10, 2019 12:07 pm
Situation:
I have 8 anchors.
They are all have the libusb-win32 (v1.2.6.0) driver from the Zadig tool.
After that the lps-node-firmware-2018.10.dfu is correctly updated with the LPS configuration tool.
But after that I can't find a way to give them a appropriate ID.
(I using the tutorial from https://www.bitcraze.io/getting-started ... ng-system/)
Re: Can't apply a ID to the anchors
Post by arnaud » Mon May 13, 2019 12:55 pm
Have you installed the Zadig driver for the anchor in firmware mode as well? If so, this is your problem.
You need to keep the default serial port driver when the nodes are running in firmware mode (ie. not DFU). If you have already set another driver from Zadig you can either uninstall and reconnect the node, or install the usb serial driver from zadig (it should be in the list of driver).
